Best cleaning solution for my monitor?
buzinski
Post by buzinski » 16 Jan 2019, 05:00
I hope it's not too dumb of a question and I hope this is the right place for it, but what would you suggest I use to clean my monitor? I eat in front of it and that's way too convenient of a habit to break so it gets rather greasy with spots of all kinds after each month and up until now I've been using the only spray my local store sells, a rather crappy one that leaves some white traces which always annoy me.Would it be advisable to use dish washing solution? Used it once some time ago on my old monitor and it did a wonderful job but is it harmful in any way?Maybe isopropylic alc?
Re: Best cleaning solution for my monitor?
Post by RealNC » 16 Jan 2019, 09:34
I bought one of these microfiber cloths at my local supermarket:
http://www.vileda.com/int/microfibre-pad-cloth.html
Optics stores (where you get glasses, contact lenses and such) also have them. It's just 2 or 3 bucks, depending on where you live.
You just make it damp with water (just damp, don't use too much water.) Just water, nothing else. It's best to use distilled water, because depending on where you live, tap water might have minerals that will stick to the display and be visible (they can look like dust or smears on the screen.) Then you clean the display with soft wipes in a circular motion. You don't need to use any detergent or alcohol. Alcohol or strong detergents can damage the display coating. In fact, those white traces you mentioned might be coating damage, if you can't clean them with the microfiber cloth :-/ Or, if you didn't use a microfiber cloth, these might be particles of paper, if you used paper. A microfiber cloth should be able to clean them in that case.
If the display is really dirty with oil/fat stains, you can buy a bottle of display cleaning solution. I never needed one, but I think they also sell them at optics stores.
You can wash the cloth with normal detergent or dish washing solution afterwards, and let it dry it so you get multiple uses out of it. Make sure the cloth is completely free of any particles when you use it again, as they can result in scratches on the display.
buzinski
Post by buzinski » 16 Jan 2019, 13:48
There's no coating damage I suppose because the solution leaves those traces on other surfaces as well and I always use microfiber.I can clean them with water afterwards but I was wondering if there's display solutions that do away with fats and/or oils and don't leave as many traces. Guess I'll have to order some new ones and hope they'll be better than the one I have.
Post by jorimt » 16 Jan 2019, 14:37
For spot cleaning, I use "Zeiss" lens wipes, which are individually packaged, disposable, and advertised as AG-safe. They don't leave a residue on mine, but it could depend on the AG coating I suppose.
Display: Acer Predator XB271HU OS: Windows 10 Pro MB: ASUS ROG Maximus X Hero CPU: i7-8700k GPU: EVGA GTX 1080 Ti FTW3 RAM: 32GB G.SKILL TridentZ @3200MHz
MonarchX
Post by MonarchX » 19 Jan 2019, 15:53
Lens cleaning solution for eye glasses with microfiber cloth for eye glasses is as good as it gets. I never had it remove any needed coating material, but water with cloth or cloth alone will not get rid of some materials and only smear them.
k2viper
Post by k2viper » 21 Jan 2019, 04:28
Distilled water + microfibre. Perfectly clean, easy, non toxic and no smells.
