Blur Busters Forums
120Hz or 144Hz on XL2730Z? (ULMB Crosstalk)
Postby HeroofTime » 07 Feb 2019, 13:46
Hi everyone,
I wonder if anyone knows the optimal route for this monitor. I've been trying to do research in regards to this issue. Older 144Hz monitors than this model are shown to have more crosstalk at 144Hz versus 120Hz. https://www.blurbusters.com/strobe-cros ... -or-144hz/
Attached are pictures (bad, but the best I could do with my S9) that show 144Hz versus 120Hz. For ULMB (Blur Reduction), intensity is set to 13 with an area setting of 10. Sadly, I can't even remember which photo resembles which Hz (I didn't jot it down, and then got sidetracked with something else), but they look nearly identical to me when it comes to crosstalk. I believe the one with the power button showing in the lower right corner is the 144Hz photo, and the one without the power button visible is the 120Hz photo.
I've also read that ULMB should be used in conjunction with V-sync. What supposedly happens is that your frames and ULMB get out of sync and make things blurry. Currently, I'm using the low lag V-sync method and I love it. I'm able to push past 120FPS almost constantly in nearly every game I play. The main game I play is PUBG though, and I'm unable to push constant 144FPS at times (even with my system overclocked to the brim). I'd say that about 25% of the time I'm unable to push 144FPS in PUBG. With that made clear, would it be best to use 120Hz instead of 144Hz? If so, I would go back to RTSS of course and change my FPS limit to 119.95FPS.
Thanks for your help and time.
https://c2.staticflickr.com/8/7871/4696 ... 6efe_o.jpg
https://c2.staticflickr.com/8/7808/4696 ... 473e_o.jpg
AMD 1800X w/ Phanteks PH-TC14PE (3850MHz, 100MHz BCLK)
G.SKILL 3200MHz CL16 16GBx2 (3066MHz, 14-14-14-14-28-42-4-6-24-1T)
GIGABYTE GTX 1080 Ti Gaming OC (2038MHz, 5940MHz)
EDIT: Forgot to state that I put my phone's camera in manual mode and tried getting the best photos that way. I had the same exact settings for both 120Hz and 144Hz.
HeroofTime
Re: 120Hz or 144Hz on XL2730Z? (ULMB Crosstalk)
Postby HeroofTime » 07 Feb 2019, 17:24
HeroofTime wrote:I've also read that ULMB should be used in conjunction with V-sync. What supposedly happens is that your frames and ULMB get out of sync and make things blurry. Currently, I'm using the low lag V-sync method and I love it. I'm able to push past 120FPS almost constantly in nearly every game I play. The main game I play is PUBG though, and I'm unable to push constant 144FPS at times (even with my system overclocked to the brim). I'd say that about 25% of the time I'm unable to push 144FPS in PUBG. With that made clear, would it be best to use 120Hz instead of 144Hz? If so, I would go back to RTSS of course and change my FPS limit to 119.95FPS.
viewtopic.php?f=4&t=3555
According to this post by Chief Blur Buster, what I've made bold in my previous post is a real thing and also causes micro-stuttering as a result. Also, I can now see a small difference in crosstalk between the two photos I shot earlier after comparing them on my PC monitor versus my phone's screen. This simply gives me more of a reason to switch to 120Hz versus 144Hz.
In conclusion, I'll be switching to 120Hz on my XL2730Z versus 144Hz due to slightly lower levels of crosstalk. Also, I can push 120FPS 90% of the time versus 144FPS 75% of the time. As a result, this should yield a smoother, more fluid experience in the games that I play.
HeroofTime
Postby RealNC » 08 Feb 2019, 11:48
Well, you can also go 100Hz. (I think 85Hz the lowest ULMB refresh rate?)
Postby HeroofTime » 08 Feb 2019, 13:03
I would've definitely tried 100Hz, but I've read multiple times that the XL2730Z has a firmware bug that will not let it properly strobe anything below 120Hz. Refresh rates lower than 120Hz will still strobe at 120Hz regardless (from what I've gathered from online posts) due to the bug in the XL2730Z's firmware.
HeroofTime
Postby Falkentyne » 08 Feb 2019, 18:51
HeroofTime wrote:I would've definitely tried 100Hz, but I've read multiple times that the XL2730Z has a firmware bug that will not let it properly strobe anything below 120Hz. Refresh rates lower than 120Hz will still strobe at 120Hz regardless (from what I've gathered from online posts) due to the bug in the XL2730Z's firmware.
The Zowie XL2730 may or may not have fixed this. I don't know.
Falkentyne
Who is online
Users browsing this forum: Q83Ia7ta and 15 guests
