Page 1 of 3
AW2518HF + Super fast responses time
Posted: 08 Feb 2019, 12:30
by Karisha91
Hello,
So I bought AW2518HF and I was so hyped about it. I’ve read so many great reviews about that monitor. But I have issue with him. When I set response time on super fast I get inverse ghosting. It’s not that big of deal but I was so disappointed to get that from 240 hz gaming monitor. First of all I come from vg248qe, and I still don’t know did I make right call. Everything seems maybe worst with new monitor. I play overwatch with 300 FPS and I still have micro stutters like on Vg248qe, thought i get rid of them with new monitor, but not. Also the reason I made this post is, is there any way to get rid of coronas, and microstutters? And plz don’t tell me to set response time to normal. I paid for super fast response time and I’ll stick to it.
Thanks for the responses
Re: AW2518HF + Super fast responses time
Posted: 08 Feb 2019, 12:44
by RealNC
It seems someone managed to fix the issue by using a custom 240Hz mode and making sure to operate the display in freesync/gsync mode. See:
viewtopic.php?f=10&t=4837#p38564
viewtopic.php?f=10&t=4837&start=10#p38589
Bottom line though is that this monitor seems to have been shipped with completely broken default parameters so you need to fix them yourself.
Posted: 08 Feb 2019, 13:09
by xXxDieselxXx
To make it simple just go to the YouTube video from RealNC's suggested links:
FYI, I also bought the monitor and I'm arming myself with knowledge
Should be arriving at any time
Posted: 08 Feb 2019, 15:03
by Karisha91
RealNC wrote:It seems someone managed to fix the issue by using a custom 240Hz mode and making sure to operate the display in freesync/gsync mode. See:
Is this still possible, because I’m using FreeSync version of monitor with gtx 1080? I’ll try everything as soon as I come home. Thanks for reply’s I’ll keep you posted
Posted: 08 Feb 2019, 15:06
by RealNC
The new nvidia drivers allow you to enable g-sync on freesync displays, so it should work.
Posted: 08 Feb 2019, 16:40
by Karisha91
RealNC wrote:The new nvidia drivers allow you to enable g-sync on freesync displays, so it should work.
okay ive found article how to set up g-sync on freesync monitor,but in nvidia settings, i dont have that option,im using currenty 418.81 driver.
Posted: 08 Feb 2019, 16:44
by andrelip
Karisha91 wrote:RealNC wrote:The new nvidia drivers allow you to enable g-sync on freesync displays, so it should work.
G-sync only works with displayport. But you can do the CRU parte even without g-sync.
Posted: 08 Feb 2019, 16:47
by Karisha91
oh yes, ive found it too. it only works with display port and im using hdmi2.0. can u tell me what do u mean CRU part?
Posted: 08 Feb 2019, 17:06
by Karisha91
Okay i downloaded CRU does anyone knows what timings should i change to create better custom resolution?
Posted: 08 Feb 2019, 20:32
by andrelip
Karisha91 wrote:Okay i downloaded CRU does anyone knows what timings should i change to create better custom resolution?
https://youtu.be/QmtJgvmd21M?t=46
