144hz Main Monitor stutter with 60hz secondary connected
Re: 144hz Main Monitor stutter with 60hz secondary connected
It appears that this behavior is fixed on Windows 10 2004, as reported on this Reddit thread: https://www.reddit.com/r/Windows10/comm ... resh_rate/
Finally.
Thanks for the heads up, I'm going to break this out on the coverpage as soon as possible.
Might be a good idea to take a look at this comment first, didn't saw it earlier: https://www.reddit.com/r/Windows10/comm ... e/fhx3apm/
It is certainly good that Microsoft began to do at least something.
But judging by this: It also appears to not work more than 3x the refresh rate of the 2nd monitor. So for example, a 240Hz monitor will be reduced to 180Hz when there is activity on the 2nd monitor running at 60Hz. Progress is not visible.
Yes, the video illustrating the change is inspiring. You can give an example of real-life tasks in which stuttering occurs on the main monitor with values of 75- (130-144).
Or I do not understand in detail?
https://youtu.be/faKlFoWYGpQ
https://imgur.com/szVrDYE
Yes, this is a solution with crutches. But it's better than waiting for favors from Microsoft.
If we assume that 0.1-0.3 FPS - stuttering.
The example with two browser windows is clear and the problem is clear. But this is not a typical user task.Chief Blur Buster wrote: ↑22 Feb 2019, 15:46Not even the same ballpark of tool because it's a Windows behaviour issue.Kheri wrote:have you tried using riva tuner's scan line sync feature?
It's like asking for a screwdriver and getting a table saw instead.
The thing is that any sync method ever invented in humankind, doesn't solve the "different-Hz multiple displays stutter problem", and a Windows 10 bug makes it worse.
Example:
1. Open two different http://www.testufo.com windows
2. Put each window on two monitors running at different Hz.
3. You will see the problem.
4. This affects all windowed applications.
This got quite a lot more attention on Reddit than I was expecting, and in multiple subreddits too. Hopefully Mr Chief Blur Buster can chime in too and provide valuable feedback, and possibly even compare his findings to mine and see what he thinks of the situation. From my understanding I believe other OS's such as macOS and Linux (still) suffer from the exact same issue, so it's good to see Microsoft (finally) getting on top of it.
Using Firefox, I was seeing some glitching (on the 144Hz monitor) when the 2nd monitor was running at 60Hz, but overclocked to over 70Hz was fine. So as I mentioned, I don't think its 100% there just yet, but with more people testing it out, hopefully MS can iron out any remaining bugs.
Yes, several news websites covered your reddit.
It's a widespread problem that many people have been complaining about to Microsoft.
New Windows Update Improves Mixed-Hz Multimonitor — With One Caveat
I used this opportunity to remind about Window's 512Hz hardware limitation which is starting to stymie some of us who are already experimenting at >512 Hz in the laboratory (forcing us to use Linux for some tests)...
This will soon interfere with the refresh rate race to retina refresh rates, as the diminishing curve of returns disappears far beyond 512 Hz. It is necessary to double Hz (60Hz -> 120Hz -> 240Hz -> 480Hz -> 960Hz...) to keep sufficiently worthwhile visible improvement. 144Hz->360Hz is a similar numeric ratio as 60Hz->144Hz. Small refresh rate increases are invisible at really high Hz, necessitiating larger jumps upwards. GPU frame rate amplification technologies will have to begin playing a role.
