Hi,
What is the best choice for PG258q in terms of clarity - best overdrive:
1. screen set to 240Hz @ 144fps
2. screen set to 144Hz @ 144fps
sadly in modern games its not possible to sustain 240fps.
PG258q best overdrive
Re: PG258q best overdrive
The medium setting is usually the best looking one on all displays. You can test yourself though:
https://www.testufo.com/ghosting
Pick the setting that has the least amount of ghosting.
