Please try not be a ******** to others. People are only trying to help. It's not our fault that you get a blurry image.ZonePhoenix wrote:Can you stop with all these shitposts? You obviously don't know how to fix it
Poor image quality after bad reboot
Re: Poor image quality after bad reboot
His system is actually outputting blurry too, that's why he would have no idea how to fix the issueRealNC wrote:Please try not be a ******** to others. People are only trying to help. It's not our fault that you get a blurry image.ZonePhoenix wrote:Can you stop with all these shitposts? You obviously don't know how to fix it
Caution! Google Translate.
What you think is blurry is a problem only for you. Not for all.
In default, my blur and color is not different from the screenshot that sent jorimt. Only after modifications it became transparent. Playing with such sharpness is nice only if you have glaucoma (https://en.wikipedia.org/wiki/Glaucoma).
But. Who are we to condemn fans hentai .
One of the versions that led to a similar result -
(https://youtu.be/DnBtoOAhba4?t=55).
I also have no solution for you. And with such a small set of data that you provided and not wanting to try what you are offered. Your most likely assistant is a person with a time machine who will send you in 2016.
(I'm not speaking English, but even through the language barrier I could sense that you are behaving like a customer in a store or an unhappy customer in technical support.)
Another useless post
You're the only person here besides me on my old machine that doesn't output blurry and you won't even explain how you did it, this is a real shame because there could have been a big breakthrough here but instead you made a completely nonsense post
Also me (blurry) vs jorimt (also actually blurry) https://imgur.com/pC60IWt
me (old rig) vs 1000watt https://imgur.com/L8pC6Wb
I hope you can solve this problem.I hate blur.
Same, i still have no idea how to fix it and 1000watt wouldn't even release his system specskaravanasam wrote:I hope you can solve this problem.I hate blur.
So no one has any explanation for this?
1000watt vs jorimt 1440:
https://imgur.com/G3mfyhe
Look at the fucking pixel layout and placement on the blue shield:
https://imgur.com/a/VCJep49
It's placing pixels in different spots on the screen in the left and right image
Am i the only person who think's that's pretty fucking serious?
We're playing shooters where we're trying to shoot accurately and with perfect precision and on 1 machine the image that's being output is actually not even indicative of the ingame logic
So on the right hand side you're playing a shooter and shooting thing's on your screen that aren't even there, the pixels literally aren't matching the graphics, so how in the fuck are you supposed to land shots?
How is no-one talking about this?
Bump, anyone know how to remove the vaseline layer off the graphics?
Installing an early 2016 windows 10 build as suggested didn't work either
Damn it's been almost a year since I last posted, almost forgot about this
As far as i could remember i last left off thinking i probably blew a capacitor somewhere on the motherboard
Never did get to the bottom of it, image quality is still shit
The best image quality i ever had was on that asus p8z77 setup, maybe it had better quality capacitors/filtering than anything else ive had since
Giving this thread a 2020 bump incase anyone has any further intel to add
