Hi Guys
i have this awsome monitor ROG Swift PG258Q and i realy have some problem see ppl some time blury picutres etc etc
i looking for best settings for the monitor color settings dark boost etc etc what should i turn on/off g sync vsync
my specs cpu i7 8800k
gpu rog 1080 ti
16 gb 3200mhz ram
ROG Swift PG258Q Correct settings for Apex Legends
Re: ROG Swift PG258Q Correct settings for Apex Legends
Sorry about the delay; now let me try to help!
Can you please describe the picture problem you have?
- Fine Horizontal lines? (inversion artifact)
- Fine Vertical lines? (inversion artifact)
- Green pixellation? (loose cable)
- Scaling artifact? (incorrectly configured GPU scaling settings)
- Blurry during motion? (bad overdrive, etc)
Etc.
Etc.
