Hello, so the question is how big of a difference between them.
In my country(Russla) price for xg2402 went into stratosphere - 425$, and xg240r is 500$.
But xg2401 is only 265$, is xg2402 worth 60% more money? Or xg2401 good enough?
Im also considering lg 24gm79g-b (260$), but i heard it has severe scanlines.
And acer xf240h (250$).
Please help me to choose, im also open to suggestions.
Viewsonic xg2401 vs xg2402, 144hz choice
Re: Viewsonic xg2401 vs xg2402, 144hz choice
XG2402 is the best 144hz monitor I ever tried, but it isn´t defo worth a 425 dollar price tag if you can buy the XG2401 for 265. I would go for the XG2401. With that being said, XG2402 is better (better overdrive and less input lag), but that doesn´t equal to almos 200 dollar difference...
Cheers
Cheers
Ainil xg2402 is 235.90 dollar on Amazon.com.You cant buy from there?Just a suggestion.
.com.... Amazon.com
You have import tax buying abroad. That price difference though...
karavanasam wrote:Ainil xg2402 is 235.90 dollar on Amazon.com.You cant buy from there?Just a suggestion.
I can, but shipping time is 2-3 weeks. And if something bad happens like dead pixels of uneven backlight it will take 2-3 weeks to return + shipping. While if i buy in Russla i can return item the same day + i will get similar item to use while they do repairs.Stitch7 wrote:.com.... Amazon.com
So i guess ill buy xg2401 :/
