165 hz Ips vs 240hz tn-big difference?
stefanbk
Post by stefanbk » 09 May 2019, 18:19
Is the difference between Tn and Ips really that big? every test about my current monitor (AOC Agon AG271QG (1440p, 27ìnch, G-Sync,IPS) says, that the difference is negligible.
Is it worth to buy a 240hz tn monitor (asus XG258Q as example), because I started to play shooters like Apex Legends seriously.
hope someone can help me :)
Monitor test from my monitor: https://www.techpowerup.com/reviews/AOC ... 1QG/7.html
1000WATT
Re: 165 hz Ips vs 240hz tn-big difference?
Post by 1000WATT » 10 May 2019, 03:20
stefanbk wrote:every test about my current monitor (AOC Agon AG271QG (1440p, 27ìnch, G-Sync,IPS) says, that the difference is negligible.
What do you attention to when comparing?
stefanbk
Post by stefanbk » 10 May 2019, 07:31
the inputlag as example.
1000WATT
Post by 1000WATT » 10 May 2019, 08:17
stefanbk wrote: the inputlag as example.
If you feel the difference on your monitor between the RTSS limit of 162 and the limit in the game.
You will also feel the difference between AG271QG and XG258Q.
Post by RealNC » 10 May 2019, 11:16
If you can't run Apex at 240FPS, I'd say it would be a bit of a waste of money :-)
1000WATT
Post by 1000WATT » 10 May 2019, 11:45
Subjective assessment. The XG258Q 240hz 120 fps ingame limit+freesync has a smaller input lag than pg279q 165hz 2000+fps.
games FPoSu \ OSU!
But it does not matter if you do not feel the difference between rtss limit/ingame limit or gsync+vsync on/gsync+vsync off for example.
stefanbk
Post by stefanbk » 10 May 2019, 15:48
RealNC wrote:If you can't run Apex at 240FPS, I'd say it would be a bit of a waste of money :-)
I can run apex at 240 ;)
and thx I will try it.
