i am interesting to buy this monitor is it worth to buy it?
this monitor https://www.gigabyte.com/Monitors/AD27QD#kf is very good? is it worth to buy it?
Re: i am interesting to buy this monitor is it worth to buy
TFT Central has reviewed this:
https://www.tftcentral.co.uk/reviews/gi ... ad27qd.htm
Seems to be a decent 144Hz IPS display. Since its IPS, the motion blur reduction mode is not that useful. You'll probably be running it in g-sync/freesync mode instead.
you mean that aorus ad27d is not good monitor??
I don't know if it's good. I don't have one. I just pointed out the review.
the review is saying that is very good corect?
My impression of the review is that it says it's a decent monitor. It doesn't say it's "very good". It does not support variable overdrive (like a true g-sync monitor can do) and thus there can be some ghosting in VRR mode, and the motion blur reduction mode has some visible crosstalk.mikedomn wrote:the review is saying that is very good corect?
So it seems it's decent. Or good. But not very good.
in most forums this monitor has very good reviews my friend
Lol sounds like you should buy it then since it's so good.
