XL2546 vs XG248Q - The best for fast response games?
Posted: 15 May 2019, 18:12
Hi all.
Finally I decided to go for a 240Hz monitor, the only ones that get my attention is the Benq XL2546 and the Asus XG248Q, but I can not decide on one of them.
I will use it to return to the competitive scene, mainly in games such as Apex, Battlefield, Pubg, Quake, among others.
The idea is to obtain the best in all aspects, for example:
- Better performance
- Reduced motion blur
- Maximum fluency
- Lower latency
- Panel image quality
- Better overdrive
- Brightness / contrast / gamma quality.
- All the above points should be taken into account, both with the strobe activated and deactivated.
CPU: Radeon VII (Optimized)
GPU: Ryzen 3XXX (possibly the 3700X)
I would love for you to exemplify the answer in order to have everything completely clear.
Thank you.
A greeting.
- Maximum fluency
- Lower latency
- Better overdrive
Thank you.
A greeting.
