24gl600f
Grimwing
Re: 24gl600f
Post by Grimwing » 02 Oct 2019, 16:25
Hey guys.
Could any of you please confirm that this is the same monitor, except the stand is adjustable?
https://www.lg.com/ca_en/desktop-monitors/lg-24GL650-B
Megatone
Re: 24gl600f
Post by Megatone » 05 Nov 2019, 13:11
This monitor is interesting.
I have sensitive eyes to brightness/light
I read Notty_PT post about brightness
But on Rtings, they have 101 cd/m² with brightness at 6, which is too much for my eyes
I had the 24G2U, but even at zero, at 89 cd/m², it was way to bright
Can it go about at least 50 cd/m² ?
singleDADAN
Re: 24gl600f
Post by singleDADAN » 05 Nov 2019, 17:15
stay away from this monitor, i sold it after 1 month i tried all settings and everything possible to make this monitor good...my main monitor was CRT OC to 120hz i dominated in battlefield all series (almost everytime MVP and accuracy with above 50% in battlefield 3 with m16a3) and paladins, then i wanted to change my crt ( its huge its not good for eyes etc) i bought this LG and i started to be noob in those games my accuracy never went above 35% i noticed and big input lag..then i bought asus xg258q and my stats come back my accuracy again above 50-60%...my advice for budget go for asus vg248qe or ViewSonic XG2402
Re: 24gl600f
Post by Chief Blur Buster » 28 Dec 2019, 14:23
singleDADAN wrote:
05 Nov 2019, 17:15
The very old VG248QE has more lag than the much newer XG258Q. That said, the XG2402 is one of the best low-cost low-lag 144 Hz monitors and is quite popular among our readers.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
mechag
Re: 24gl600f
Post by mechag » 24 Mar 2020, 07:53
Hi,
Has anyone tried overclocking this monitor? How high can you go without issues and when the 'out of range' sign shows up, has anyone found a way to remove it?
Thanks
