Asus XG258 Questionable Overdrive
singleDADAN
Re: Asus XG258 Questionable Overdrive
Post by singleDADAN » 05 Nov 2019, 16:23
Paft wrote:He already said what settings he uses in this thread:
viewtopic.php?f=2&t=5415&p=41696&hilit=settings#p41696
Here's the file if you use 'ASUS DisplayWidget':
(My Gdrive is full so it will have to be mediafire)
http://www.mediafire.com/file/1lpa3lkba ... ty_PT.axml
are those settings he use for gaming ? ddc/ci on or off ? and asus displaywidget not working for me: "Selected monitor not supported"
Paft
Post by Paft » 05 Nov 2019, 16:37
Yes.
I don't think he mentioned DDC/CI. I don't even see those in my monitor options.
Did you download it from the correct page?
https://www.asus.com/us/Monitors/ROG-St ... _Download/
singleDADAN
Post by singleDADAN » 05 Nov 2019, 16:58
Paft wrote:Yes.
system setup->OSD setup
yep i download from official site, tried also diferent versions none works...
quote from some other forum:" make sure to disable ddc/ci add input lag aswell(if you don't need it for anything)"
Paft
Post by Paft » 05 Nov 2019, 17:09
Ah yes, of course. I haven't touched my monitor since I started this thread. I have a terrible memory.
I just noticed DisplayWidget isn't working for me now. "Selected monitor not supported". Strange because I used it the other day to re-apply notty's settings because I saved over it by accident.
I reset the monitor for factory settings and DispalyWidget works again. Go to Advanced Settings>Import
Disable it from starting with Windows because it's buggy for me. It likes to switch profiles on its own. Usually switches to racing.
singleDADAN
Post by singleDADAN » 22 Nov 2019, 05:04
https://prnt.sc/q0i7p9
against vs crt monitor. Clone mode.Both on 1920x1080@60hz
Post by RealNC » 27 Nov 2019, 00:50
singleDADAN wrote:
22 Nov 2019, 05:04
What happens if you swap the monitors? Clone mode sometimes has lag.
