Hello,
I own a BenQ ZOWIE XL2546 with 240Hz and Dynamic Accuracy (DyAc). Whenever I enable DyAc, my brightness increases significantly. When I turn it off, the image becomes rather dimmed / dark-ish with a subtle green glow.
1. I would like to be able to turn off dynamic accuracy, but keeping the brightness levels of DyAc mode. Is there any chance I can manually add them to non-DyAc mode using factory settings or something similar?
2. An out-of-topic question: With DyAc, I notice a severe flicker making it incredibly uncomfortable at fast motions. Now I've read a fair bit about strobing etc (I was accidentally using Nvidia's ULMB before), but I never noticed such a huge difference. DyAc gives me next to nothing just by pure feeling. As far as I can tell, that should've been a feature where I can see a clear difference when for example spraying a rifle in csgo, right? I obviously notice a massive difference, but I don't feel any advantages, just disadvantages. Is it just a possibility that I cannot deal at all with flickering?
3. I haven't quite understood AMA (off / high / premium) yet. Well, kind of. However, I mostly prefer it to be turned off I think. When I do the ufo ghosting test, AMA on high / premium gives me more clarity at the end of an ufo. However, it adds a noticeable white ghost trail. I have already manually decreased this so called "OC grain". I believe that's the intensity of AMA found in those factory settings. However, when I switch into csgo for example, I do a little test where I walk left and right. When doing this while AMA is on, I notice the above mentioned white ghost trail to objects / corners. It seems my prefered setting with AMA is off right now as it elimnates all ghosting trails. So what is AMA supposed to actually do? I visually can only see its disadvantages.
Conclusion:
When doing the UFO ghosting test, I achieve the best looking image with AMA High + DyAc Premium. However, when using those settings ingame, I cannot deal with it. It seems I actually prefer AMA off and DyAc off.
Is it just my preferences that are "out of the order"?
Have I gotten a faulty monitor?
4. Should I possibly consider returning my monitor and get a cheaper one instead since I don't need any of those fancy settings?
BenQ ZOWIE XL2546 - Brightness, DyAc & AMA
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
