Pixels not matching
stertyr
Pixels not matching
Post by stertyr » 18 Jun 2019, 14:39
Hello
I have been trying to figure out problem I called msyelf "pixel matching" I don't know if there is official "name" of this problem.
I have xb271huabmiprz but also had it at xl2430 and iiyama one.
So let's say i have static image but when I move whole screen is like flickering at some points. It's caused by "moving pixels" When I play games some edges looks bad, like pixels aren't matching this edge line correctly. If i move my mouse just by let's say 1 unit, then the pixels change their position of the edge. So when I am playing normally and moving fast it causes the whole map flicker(all edges and familiar things are moving their pixels).
Any way to solve that or is that TN's fault?
Re: Pixels not matching
Post by jorimt » 18 Jun 2019, 15:15
Do you mean "aliasing?"
What (I think) you're describing can be caused by aliasing from both pixel and subpixel geometric edges in static scenes and in motion (including "shimmering" effects from specular highlights in-game; metal/reflective edges), as well as sometimes on textures at extreme angles due to filtering issues.
These can be addressed by "anti-aliasing" and "texture filtering," both of which are usually available as in-game graphical settings, and vary in naming, methodology, and effectiveness.
Barring lower native resolutions (aliasing decreases the higher the monitor's native res and in-game res is), neither are the direct fault of the monitor; the blame lies with games being rendered with pixels.
That, or you may be referring to "inversion artifacts" or GTG/overdrive artifacts (or a combo of all). Hard to say with such little info or evidence to go off of.
