Hi. I just bought this monitor. when i change it to 144hz in windows the screen split in half and half of it looks yellowish in bright colors like white and about black lines in blue, is there a problem with the monitor or should i tweak some settings? can someone help me please? these are the imgs ive taken with my phone
Thanks
Asus Mg248Q
Re: Asus Mg248Q
I've seen panel defects that look like this -- modern LCDs are often partitioned in vertical strips that are driven with concurrent refreshing -- left half, right half (or even 1/4th 1/6th or 1/8th width strips).
There might be a defect that becomes visible when the monitors' limits are pushed, assuming you see this with all cables on all ports you've tried, from two different computers. If that is the case, I would declare RMA on this monitor.
