I'm using the G2460PF since 2016 but I'm not happy with the colors, especially dark areas and shadows look quite washed out.
I use the settings that are recommended in the review on pcmonitors.info.
Is it worth upgrading to a new monitor with TN-panel? I mostly play fast paced esport games, so I don't want to go for VA. But I'm not sure how much of an improvement a new model would make.
Also, how do the 240hz models compare to 144hz models in terms of color and contrast?
Worth upgrading from AOC G2460PF?
Re: Worth upgrading from AOC G2460PF?
The ViewSonic 240Hz monitors have some of the better TN colors I have seen, if you want to raise the importance of TN color quality. It's not perfect but the best TN panels have better colors than the worst IPS panels -- just that viewing angles are a bit tighter.
Also, you can also try the new 240Hz 1ms IPS panels too, they are getting some pretty decent reviews currently.
