I can't explain it, it's absolutely insane. It's the most blurry monitor I have ever used and I can't explain why it could possibly be like this. I think I'm gonna try to get a refund, because I simply can't play competitively on it.
Send me links to any tests you want images of, I'll do anything as soon as I see it.
Acer KG271B 27 inch 240Hz monitor has the craziest blur
Re: Acer KG271B 27 inch 240Hz monitor has the craziest blur
May be you got just defective sample? I have BenQ XL2540 and this Acer. They perform same for me or very close. May be you describe how it works with motion blur reduction ON?
good test is https://www.testufo.com/ghosting
