Should I keep trying to clean these?
buzinski
Post by buzinski » 06 Aug 2019, 13:07
So i've been an idiot and left oil spots for longer than usual on my monitor and now I just can't clean the bloody spots even with dishwashing liquid, at least not entirely. I have 5 of these on my dell aw2518h monitor: https://imgur.com/a/7SCd9UM
I managed to clean enough so that they're impossible to see with the display dry no matter how I look at it or how I shine a flashlight on it, but will they cause any harm to the coating in time? I might keep on scraping the display some more but I'm afraid that would damage the coating.
Re: Should I keep trying to clean these?
Post by Chief Blur Buster » 16 Aug 2019, 16:56
Continuing to clean will cause some further inconsistencies -- there is a risk of too much polishing-down the matteness of the antiglare coating -- which can look worse than an almost-gone oil spot. There are solvents designed for monitor screens that work much better than dishwashing liquid, and doesn't require you to riskily scrub with a cloth.
But at this stage -- if it's good when dry, then it's best not to do any further action -- it's possible to overpolish a matte film, creating glossy-vs-matte inconsistencies on the coating.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
