Is there a reason my monitor is saying free sync is enabled?
https://gyazo.com/9f9bb04c78fd66d3134a72746dd9f6f6 On the screenshot it says I have free-sync on when I disabled it on nvidia control panel. Idk if its a visual bug but it wasnt like this before. Anyone know a way to fix? Also, is this normal? https://gyazo.com/89b56a3305a530276f278103f5e84dae I'm using premium overdrive and it looks like this. My monitor is a xl2540 and it feels like targets in a game like overwatch become blurry when the move.
Re: Is there a reason my monitor is saying free sync is enab
Sometimes the FreeSync setting is an ON/OFF setting on the monitor too -- so that you can enable it both monitor-side and computer-side.
If there is no FreeSync setting on the monitor OSD, then it's probably OK to not worry about it. You can try rebooting your monitor (unplug-plug) after turning off via NVIDIA -- and see what happens to the setting. FreeSync ON/OFF doesn't often dynamically happen.
Fortunately, I don't think it's anything to worry about in your particular case.
To support Blur Busters:
• List of G-SYNC Monitors
• List of FreeSync Monitors
• List of Ultrawide Monitors
