Acer XF252Q - this is my endgame
daviddave1
Re: Acer XF252Q - this is my endgame
Post by daviddave1 » 18 Aug 2019, 11:47
double post.
daviddave1
Post by daviddave1 » 20 Aug 2019, 06:32
steel116 wrote: I've tested ViewSonic XG2402 (didnt test the newer XG240R tho) but it was really good.
steel116 wrote: The best thing i've noticed playing on this monitor, is that it handles well playing at 150FPS with monitor set at 240hz. The gameplay is smoother, there is way less stuttering and tearing because of the disparity.
Im torn between the XG2402 and the Acer XF252Q i only play games that can get 140 fps stable like PUBG, Apex Legends and Quake Champions.
Is there a difference between the XG2402 and the Acer XF252Q @ 150 fps? About the same or is the Acer XF252Q still better?
steel116
Post by steel116 » 22 Aug 2019, 03:38
sdx wrote:Can anyone do pursuit pictures to compare to hp omen x 25f? Strobed and non-strobed 240hz? 144hz strobed? TFT's strobed images looked pretty bad.
I dont have myself a good camera to take a shoot of it, but i'll tell you how this looks like.
on XF252Q on FreeSync (with G-Sync Compatible enabled) ghosting ufo looks the best along all monitors i have tested (240hz) (without VRB)
but if you turn on VRB (strobing) it doesnt look so good anymore. I just don't recommend using it at all, no matter which overdrive you set, there is a corona around the ufo, pretty unnatural and looks actually bad.
Kcin
Post by Kcin » 06 Oct 2019, 12:25
Do you have inversion artifacts on this one? They manifest like vertical scanlines when you focus on slowly moving objects.
Like if I look on the grey bar in this test - https://www.testufo.com/inversion#patte ... bars&ppf=1 - I can see vertical lines and these manifest here and there - and annoy to no end.
DukeDice929
Post by DukeDice929 » 02 Nov 2019, 08:47
Hello, guys. I'm looking to buy this monitor. Can you please tell, does it support custom refresh rate via CRU (custom resolution utility)?
My bad English :0
mitch.99
Post by mitch.99 » 02 Nov 2019, 19:29
Hey so if i play all sorts of games like comp, story, racing, mmo. On comp ill run low settings but everything else will be like high settings.. ill have a 9900k/kf and 2070super.. should i still get a 240hz vs 144hz? Whats bad about running 100-144fps on 240hz monitors? What about using g sync compatible on those low fps games?
Is the alienware AW2518HF really that bad? I swear people say the input lag is pretty good. Im really new to learning about monitors and im struggling to figure this out for my new build i got till the end of the month.
