Blur Busters Forums
ASUS XG258Q frame skipping?
Postby pwn » 13 Aug 2019, 11:13
Can someone tell me how what is happening on the screen is normal?
https://drive.google.com/drive/folders/ ... sp=sharing
Manufactured: March 2018
pwn
Re: ASUS XG258Q frame skipping?
Postby oof_oof » 13 Aug 2019, 13:09
does that go away when you turn on freesync / adaptive sync?
oof_oof
Postby pwn » 13 Aug 2019, 13:38
oof_oof wrote:does that go away when you turn on freesync / adaptive sync?
no
After I turn on adaptive synchronization, nothing changes.
pwn
Postby pwn » 14 Aug 2019, 06:43
If vertical synchronization is disabled in Nvidia drivers, then there is a problem.
And if it is turned on or in auto mode, then everything is fine ..
pwn
Postby pwn » 14 Aug 2019, 12:23
upd2.
The monitor does not understand how many FPS is displayed on the screen. (Through the standard menu, you can display the FPS counter)
I will take on RMA
pwn
Who is online
Users browsing this forum: No registered users and 17 guests
