Hello, im searching for a 240 hz monitor (mainly for csgo, apex and rainbow six). So far ive found alienware aw2518hf (320€), aoc ag251fz (330€) and BENQ xl2540(380€).
Also been looking for Acer xf252q (about 320 GB pounds). But it would have to be bought from outside my country which is Portugal.
I really cant decide which one is considered the "best" so any help would be really apreciated.
(also i was trying to spend less than 350€ but could make the stretch for 380.)
Need help choosing 240 hz monitor
Re: Need help choosing 240 hz monitor
You should buy the Omen X 25f if you want the lowest input lag.
See this thread : viewtopic.php?f=2&t=5587&start=60
Maybe a little above your budget.
But the Website that tested the omen didnt test any of the others. I think i can get the Acer xf 252q 299 GB pounds. And its advertised as 0.3ms GtG. Ive only heard good things about it as well
The website also tested the BENQ xl2540 https://www.rtings.com/monitor/reviews/ ... wie-xl2540 and the hp is doing better in terms of input lag.
I saw today that rting will also review the acer : https://twitter.com/rtingsdotcom/status ... 3393536000
So maybe you should wait for the result if you really want to compare.
