HP Omen X 25f low blue light?
Odin76
Post by Odin76 » 29 Aug 2019, 08:48
Does the HP Omen X 25f has a low blue light feature?
do0om
Re: HP Omen X 25f low blue light?
Post by do0om » 29 Aug 2019, 13:06
It has a low blue light color settings if it's what you are looking for. I don't think that's better than softwares like flux except it shouldn't have added input lag. (I didn't measure)
Odin76
Post by Odin76 » 29 Aug 2019, 13:31
do0om wrote:It has a low blue light color settings if it's what you are looking for. I don't think that's better than softwares like flux except it shouldn't have added input lag. (I didn't measure)
Cool, do you know if the blue light filter is a slider or is it an on-off type setting?
do0om
Post by do0om » 01 Sep 2019, 09:59
That's just a color preset with R=253 G=220 and B=200. So you can tune RGB individually after.
