HP Omen X 25 or X 25f
OwBoNo
Post by OwBoNo » 06 Sep 2019, 01:36
What are the advantages of the Omen X 25 over the X 25f?
Both have G-SYNC, but X25 has a G-SYNC Module whereas the 25f is ''Variable Refresh Rate G-SYNC Compatible''.
Which one do you think will have a better overdrive less ghosting?
Has their been any differences in other 240Hz G-SYNC vs Non 240Hz G-SYNC monitors?
I'm willing to pay for the G-SYNC Module if it will have a better overdrive/less motion blur ect.
pox02
Re: HP Omen X 25 or X 25f
Post by pox02 » 06 Sep 2019, 06:21
OwBoNo wrote:What are the advantages of the Omen X 25 over the X 25f?
X 25 since its have Variable Overdrive Full variable refresh rate
monitors xg258q aw2518hf 27GK750F-B pg248q xg240r lg w2363d-pf xb270hu
