Rtings - Acer Nitro XF252Q review is up :)
Leki
Post by Leki » 06 Sep 2019, 10:39
https://www.rtings.com/monitor/reviews/ ... tro-xf252q
"The Acer Nitro XF252Q is a bit better than the HP OMEN X 25f."
well time for me purchase along with a 5700 XT :)
pox02
Re: Rtings - Acer Nitro XF252Q review is up :)
Post by pox02 » 06 Sep 2019, 11:55
you know why its better? Black Frame Insertion :)
monitors xg258q aw2518hf 27GK750F-B pg248q xg240r lg w2363d-pf xb270hu
Xzwer
Post by Xzwer » 06 Sep 2019, 11:58
I absolutely love this monitor, I just can't find any flaws with it. I play without V and G-sync(freesync) sometimes with VRB (Black Frame Insertion) and sometimes without it (can't decide what's best) with 260fps limit.
Anyone got any opinion on that VRB option? What's the pros and cons of using it? I can sometimes in certain conditions see some weak black lines across the screen with it enabled on extreme mode but it doesn't really bother me.
disq
Post by disq » 06 Sep 2019, 12:11
If only they tested the XL2546 now :roll:
Leki
Post by Leki » 06 Sep 2019, 12:56
pox02 wrote:you know why its better? Black Frame Insertion :)
For me in UK the Acer also costs £50 less as the acer goes for £298, acer also has a lot more features that i will use such as more USB, black boost to lighten up dark areas in games and built in speakers for when i can't be bothered keeping headset on :)
Will give the black frame insertion feature a go too :)
