Blur Busters Forums
good 144hz 1080p Monitor with VESA mount.
Postby Hoangnguyen » 08 Sep 2019, 21:29
Hi guys,
I'm looking for a good 24" 144hz 1080p Monitor with VESA mount, I'm playing League of Legends and sometimes shooters. What would you recommend? I am looking at these now:
Viewsonic XG2401
AOC G2460PF
BenQ ZOWIE XL2411P (a bit more expensive than the others, worth it?)
Or something else that costs about the samen???
Hoangnguyen
Re: good 144hz 1080p Monitor with VESA mount.
Postby Chief Blur Buster » 09 Sep 2019, 15:10
Yes, most 144Hz 1080p monitors have hidden VESA mounts -- you unlatch from the monitor stand and mount the VESA bracket to the rear.
Check the XG2402 as well, as that is the newer sibling of the XG2401, although the XG2401 can be found cheaper at some sales (not always).
The XL2411P is good if you want motion blur reduction features, and it is also compatible with Blur Busters Strobe Utility.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Who is online
Users browsing this forum: jorimt, MSN [Bot] and 9 guests
