Reduce motion blur on Acer Predator Gaming Z321QU & PS4 Pro
kingeryck
Post by kingeryck » 11 Sep 2019, 17:53
There's noticeable motion blur when playing the PS4 and I feel like there shouldn't be with this monitor. It's set to 160mhz right now. What can I do to reduce the blur?
Re: Reduce motion blur on Acer Predator Gaming Z321QU & PS4
Post by Chief Blur Buster » 11 Sep 2019, 18:38
The Z321QU monitor is a VA panel -- they tend to ghost quite a bit in dark colors.
To minimize ghosting on VA panels:
(1) Warm the panels up for 30 minutes. They perform much better when warmed up.
(2) Adjust colors to be brighter, or brighter gamma (make the grays much brighter). This can avoid problematic ghosting in certain games.
I suggest a fast IPS panel or a fast TN panel if you want better 60fps at 60Hz console gaming. And if motion blur was still a problem with those, motion blur reduction features are also an option but are not as common at 60 Hz (except on certain models such as the BenQ XL2411P).
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
TTT
Post by TTT » 17 Sep 2019, 11:36
The screen probably isn't running at its max hz, the HDMI input will be locked to 60hz.
And what chief said VA is blurry and traily, it gets better at higher fps but thats only possible on a PC.
