Hi all,
Acer named two products the same name. The original product didn't have G-Sync and had a bunch of ports such as DP/DVI/VGA/HDMI and one with G-Sync that only has one port. The only way to distinguish between the two is the ports and if 'Abpr' is in the title. If you don't know this it's very easy to buy the wrong product.
I recently got very confused trying to buy a monitor for a friend. This is insane, Please just put G-Sync in the title.
Thanks
Two products the same name
Re: Two products the same name
Thank you, now they put G-Sync in every Free-sync model since they are G-Sync compatible.nobita123 wrote:This is insane, Please just put G-Sync in the title.
Thanks
