GD-28U240
UHD60HZ, FHD240HZ
full of shit.
https://youtu.be/5tRIdCNrMMM
it's 240hz mode in both nvdia and intel graphic option. and my card is 2080ti
is this a problem of software(drivers or etc) or I just bought trash monitor?
Frame skipping issue
Re: Frame skipping issue
trash monitor sorry i never heard of Shaanxi SYC Electronics Technology seems they using old panel with huge voltage overclock to make 240hz that make frame skipping
Thx for answer. Now only I have to do is fight with trash company.Thx again. hope you have a good day
You can try to alter the timings with CRU to see if it helps with frame skipping. You can search for "CRU timings fix frameskipping" on the internet to find some guides that might help you with experimenting with CRU.
Thx for information, But none of them don't work too. I called the company and they admit their fault. I hope everyone learn a lesson from my case.You get what you pay for.RealNC wrote:You can try to alter the timings with CRU to see if it helps with frame skipping. You can search for "CRU timings fix frameskipping" on the internet to find some guides that might help you with experimenting with CRU.
