Bought the HP Omen X 25f
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 17 Sep 2019, 07:51
About a week ago I went to my local Best Buy just to check out the HP Omen X 25f. They had one on display and it seemed like a well built piece of hardware, but at $449 it turned me away. Yesterday I was out and about doing a few things and I decided on a whim to stop back and ask about their return policy just in-case I wanted to give it a test run. The first thing I noticed was the price dropped to $329. It was $120 off the original price :o :shock:
I'm coming from an Asus VG248QE that I've had since flat panels came out. While it was a fast monitor, the HP Omen X 25f is obviously faster but I want to make sure it's using the latest panel, among a few other things like, make sure it's the best of the best right now, how to set it up properly, register it, etc.
I did set it Level 3 according to RTings "Best Overdrive Setting" and that's about as far as I got. I don't use G-sync or FreeSync just the standard 240Hz refresh rate.
What else do I need to do?
TTT
Re: Bought the HP Omen X 25f
Post by TTT » 17 Sep 2019, 11:38
What are you actually asking? How to set up NCP?
Tenobaal
Post by Tenobaal » 17 Sep 2019, 12:37
There's no official statement about the panel used. Some rumours say it is the latest and some decline that. I went with Acer xn253qx because there was a review.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 18 Sep 2019, 10:19
TTT wrote:What are you actually asking? How to set up NCP?
I'm curious if I need to register the monitor. If anything needs adjustments. What's NCP?
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 18 Sep 2019, 10:20
Tenobaal wrote:There's no official statement about the panel used. Some rumours say it is the latest and some decline that. I went with Acer xn253qx because there was a review.
RTings did a review of the Omen X 25f
https://www.rtings.com/monitor/reviews/hp/omen-x-25f
Rowdy
Post by Rowdy » 19 Sep 2019, 12:31
You might as well use G-Sync with it since it has no drawback on input lag.
TTT
Post by TTT » 20 Sep 2019, 18:20
Nvidia Control Panel.
Just figure out the colour settings you like, the Lagom.NL pages are pretty helpful for self calibration.
Try out Gsync, on a 240hz you can't see screen tearing anyway but Gsync adds a different smooth feeling and makes the motion different.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 20 Sep 2019, 21:49
How do I do Gsync on this monitor? Thought it was Freesync supported but Gsync unofficially supported
TTT
Post by TTT » 21 Sep 2019, 10:01
Its just under nvidia control panel, gsync tick box.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 21 Sep 2019, 11:34
TTT wrote:Its just under nvidia control panel, gsync tick box.
I must have something configured wrong cause I don't see it anywhere. I've looked through the 3D settings, Display, and Video, on the NCP.
I use NV Slimmer and just install the required features + PhysX. I've also disabled the ... OK found it mid way through this post. I had the 'Adaptive-Sync' disabled via the monitor. Turned it on and it showed up in the NCP.
