Found the best gaming monitor by accident
BlurBoss
Post by BlurBoss » 29 Sep 2019, 05:07
Hey guys, I've been trying out different monitors to find replacement for BenQ XL2456, as I became very sensitive to FPS drops below 240 FPS in my favorite game Rainbow Six siege. I was considering purchasing Aorus KD25F again and staying with it at G-Sync+160 Hz, but wanted to see what other manufactures have come up with. So, I ordered Acer XN253Q and received 144 Hz version of it, which I didn't know existed:
XN253Q Pbmiprzx - 144 Hz
XN253Q Xbmiprzx - 240 Hz
https://www.acer.com/ac/en/US/content/p ... redatorxn3
Is there an advantage of going with 144 Hz panel over 240 Hz panel (which I didn't try) on Acer XN253Q? How can I find out what panel I have? HWiNFO shows the panel as "Acer [Unknown Model: ACR06D0]"
This monitor is amazing! With ULMB on at 120 Hz (can't enable it with 144 Hz) UFO is clearer than on my BenQ XL2456 with DyAc on at 240 Hz, but this monitor has no overshoot at all! The colors also looks as good as on Aorus KD25F and Aorus AD27QD. I only tried ULMB on Aorus KD25F with 240 Hz and while the picture quality with ULMB disabled was great, ULMB on was somewhat darker.
With picture quality that good, with clearer motion with ULMB on than on any monitor I've tested (although a bit darker than on BenQ XL2456), with no more 240-180 FPS fluctiations, I'm keeping this monitor as it provides the best gaming experience for me. Here is the list of monitors that used daily for 7 days:
Aorus AD27QD
Aorus KD25F
Acer XV273K
BenQ XL2450
BenQ XL2456
ASUS PG258Q
Asus XG248Q
Viewsonic XG240R (just returned it yesterday)
Samsung C32HG70QQI
Samsung C49RG90SSI
Samsung C49HG90DMI
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
pox02
Re: Found the best gaming monitor by accident
Post by pox02 » 29 Sep 2019, 11:32
BlurBoss wrote:Hey guys, I've been trying out different monitors to find replacement for BenQ XL2456, as I became very sensitive to FPS drops below 240 FPS in my favorite game Rainbow Six siege. I was considering purchasing Aorus KD25F again and staying with it but wanted to see what other manufactures have come up with. So, I ordered XN253Q and received 144 Hz version of it, which I didn't know existed:
Aorus AD27QD
Aorus KD25F
Acer XV273K
BenQ XL2450
BenQ XL2456
ASUS PG258Q
Asus XG248Q
Samsung C32HG70QQI
Samsung C49RG90SSI
Samsung C49HG90DMI
dam nice found 144hz with gsync !!! i was searching for monitor like this for months omg thanks do you know places that sell that model? nvm found it just order this model :D
i know XN253QX use m250htn01.9 not sure about the QP but im guessing m250htn01.6
monitors xg258q aw2518hf 27GK750F-B pg248q xg240r lg w2363d-pf xb270hu XL2546 XL2546K NXG252R AW2521H(main) :D
Q83Ia7ta
Post by Q83Ia7ta » 01 Oct 2019, 05:50
BlurBoss wrote:How can I find out what panel I have? HWiNFO shows the panel as "Acer [Unknown Model: ACR06D0]"
Only by disassembling or by monitor's service menu if you are lucky. No way that other software can get this information and even monitor's service menu can't be a reliable source since it's just a string value. Btw was there there any cases when monitors assemblers (brands) change panel from batch to batch or from factory to factory? This is common behavior for ssd market or some smartphone assemblers like to use several models of lcd panels in their one smartphone model.
Odin76
Post by Odin76 » 01 Oct 2019, 08:53
So you recommend this over the 240 hz variant? Do people pick 144 hz over 240 hz anymore?
pox02
Post by pox02 » 03 Oct 2019, 05:11
Odin76 wrote:So you recommend this over the 240 hz variant? Do people pick 144 hz over 240 hz anymore?
Yes most of the games cant reach 240 fps and 144hz is sweet spot for all games
BlurBoss
Post by BlurBoss » 04 Oct 2019, 04:26
I do recommend this over 240 Hz (I've tried Aorus KD25 but haven't tried XN253Q Xbmiprzx), and I would play on XN253Q Pbmiprzx at 120 Hz + ULMB. In fact I'm playing on it right now and using BenQ XL2456 at 240 Hz as secondary montior to type this message.
jombotski
Post by jombotski » 04 Oct 2019, 05:28
Really informative post.I recently got the aorus ad27qd because and it was my first IPS monitor,i was always on crt monitors then moved on to tn panels,so i thought the ips is gonna mind blow me,but it was nothing special.Actually the motion blur is horrible.So i was searching for low motion blur and found this thread.Because for me the motion blur makes the games unplayble.So do you think its worth it to sell my aorus(i mean i cant return it because i had it for a couple of months already) and buy this acer ? In your personal experience with so much monitors, is it big difference to go from 1440p to 1080p ? Me personaly this was my first 1440p monitor so i dont know how i am gonna feel again if i go to 1080p.
BlurBoss
Post by BlurBoss » 04 Oct 2019, 09:58
I actually had Aorus AD27QD for a week and wouldn't even pick it over BenQ XL2456. It does provide much better picture than BenQ XL2456, and a little bit better picture than Acer XN253Q P, but it was very slow in Rainbow Six Siege and Apex Legends and it's ULMB is very dark. 1440p did give a little bit of detail and I could move 27" monitor a little further away (and lean forward for more details, leaning forward on 1080p doesn't give more details). I personally would only play RPGs or Strategies on Aorus AD27QD, but I haven't played them in 10 years. If you could return a monitor for any reason, I'd recommend purchasing another one and comparing them side by side.
Tenobaal
Post by Tenobaal » 04 Oct 2019, 12:32
I've got the XN253QX with 240Hz and 237FPS in Siege is not a problem (I play with downsampling WQHD). Although I prefer [email protected] Maybe the difference is minor but why take 144Hz when 240Hz is available? It only makes sense if you can't afford the XN253QX.
pox02
Post by pox02 » 04 Oct 2019, 14:59
Tenobaal wrote:I've got the XN253QX with 240Hz and 237FPS in Siege is not a problem (I play with downsampling WQHD). Although I prefer [email protected] Maybe the difference is minor but why take 144Hz when 240Hz is available? It only makes sense if you can't afford the XN253QX.
consistent overdrive not suffer from stutters when fps below 144 fps most of the games cant reach 240 fps there huge reasons why 144hz still popular
