AW2518HF Overdrive setting
Hello, i have a AW2518HF which is a 240hz freesync/gsync compatible monitor, and i currently use Gsync + Vsync with fps capped to 237. Question is tho, what overdrive should i set. I can choose between normal to super fast but have no Idea what the setting does. Does it remove ghosting, or add ghosting for lower input lag ? What's the best setting, if anyone can answer me that, thank you.
Re: AW2518HF Overdrive setting
