@Max_hz
Thanks a lot for your reply, can you tell me the exact VG259Q locked off brightness level in the sRGB mode? (not the cd/m² value, just what you read in the monitor's OSD - for example in the AOC 24g2 is fixed at 90 out of 100)
ASUS VG259Q
Re: ASUS VG259Q
Unfortunately there is no information regarding the initial SGRB settings in the OSD menuHansen79 wrote:@Max_hz
In use: Asus VG259QM IPS 240-280hz - Hanns-G HS233 TN 120hz
Used before: LG 24LG600 TN 144hz - HP Omen X 25f TN 240hz - ViewSonic XG2402 TN 144hz - Asus VG259Q IPS 144hz
Re: ASUS VG259Q
A reddit user (thejessedurden) reviewed the VG259Q, he used a amplified photosensor connected to a oscilloscope for measure response times;
https://www.reddit.com/r/Monitors/comme ... onse_time/
Link to review;
https://www.reddit.com/r/Monitors/comme ... aming_ips/
Link to review;
