Hi guys, this is the first time I write on this fantastic forum where I found a lot of valuable information offered by you. I want to ask you 2 questions:
https://www.rtings.com/monitor/reviews/lg/27gl650f-b
1° Since I recently purchased the LG 27gl650f-b"VRR", I would like to know if the solution I adopt is optimal or should I change something to get the best in terms of performance? I use G-SYNC + Low latency mode at ultra + in-game fps cap 141 "should I insert the V-Sync on?" Also in games where I play the frame rate is very stable at 141.
2° This less important. I have seen that on this monitor the "Dynamic action sync" DAS is advertised in the OSD I do not see any settings in this regard, this makes me think that it is already pre-activated and without the possibility of activating / deactivating it, can anyone confirm?
Thank you for a possible reply!
Best settings for performance "LG 27gl650f-b"?
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
