Acer Predator XN253QX - Your Thoughts
Dricks
Re: Acer Predator XN253QX - Your Thoughts
Post by Dricks » 19 Jan 2020, 04:17
BlurBoss wrote:
19 Jan 2020, 02:03
Are you on the latest version of Nvidia drivers? I'm interested in 3d too.
Yes, i'm using 441.87 with injected 3DVision from 425.31 drivers
https://www.mtbs3d.com/phpbb/viewtopic. ... 05&t=23277
After searching all day long, i found a way: creating my own EDID Override based on my AW2518H which is also a 240hz Gsync 1920x1080 monitor.
And it worked!
So here it is:
https://drive.google.com/open?id=1NZQHR ... 2E1FWxRgxX
Download it and set it as your new monitor's driver
It should work with all 240hz Gsync 1920x1080 monitor
Before:
After:
Dirty Scrubz
Post by Dirty Scrubz » 19 Jan 2020, 05:54
I think NVIDIA removed 3DVision from the latest drivers.
dadaw
Post by dadaw » 21 Jan 2020, 17:57
One question people. When we put this screen in 144hz mode for the ULMB, The extra input lag comes from putting the screen into 144hz mode itself or its the Black image insertion?
XB273QX , Benq 2K 60hz , 8600K @ 5gHZ, 1080Ti , 2x8Gb 3200mhz CL14, Aorus Master Z390
Dirty Scrubz
Post by Dirty Scrubz » 21 Jan 2020, 18:27
dadaw wrote:
21 Jan 2020, 17:57
Probably a bit of both.
phixion
Post by phixion » 29 May 2020, 15:40
I bought this for £379, a great buy IMO considering it is full G-Sync module and it's using the new TN panel.
I have come from a Dell U2410 IPS panel and bought this for gaming. Of course, it exhibits the usual TN issues, but they seem to be far less pronounced, it's the best TN panel I've ever seen. Amazingly, my unit has no BLB.
Viewing angles are surprisingly good, viewing from angles turns white to yellow, but the image is still visible.
The panel is slightly darker at the top than the bottom, but this is expected with TN.
I was waiting for the 25" IPS Predator to release, but it is taking so long and the price on this TN has dropped so much (originally £499) I couldn't resist.
I'm interested in the settings you guys use. Here are mine:
Brightness 15
Contrast 40
Blue Light Off
Dark Boost Off
Adaptive Contrast Off
Gamma 2.2
Color Temp. User
This looks best for me, the whites aren't so blinding, yet they are still white.
I tried some settings from other sites and they all seemed too bright.
Acer Predator XN253QX 240Hz G-Sync
