I have gtx 750 ti and gtx 670 i know both are pretty bad but i only play cs go and wanted 240hz so which is better to use?
gtx 750 ti has new architecture which "natively?" supports 240hz but 670 is a bit faster.
Which GPU is better for 240hz?
Re: Which GPU is better for 240hz?
If both hit 240, use the newer architecture, or what's quieter? I don't think these can be compared objectively, but if the 750ti can run it 240 on the required settings and be adequately loud at that, use it, I guess.
