Eye strain problem
rasmas
Re: Eye strain problem
Post by rasmas » 13 Mar 2020, 10:37
Very interesting thread. I always like to look at monitor-TVs from the side to see if it adds some colour, and thought is was just TNs because of their bad angles, but never knew it could be the anti glare coating (too?).
OLED TVs are the best when looking at its side and i wonder if it is only because of being OLED. Also some time ago i read this reddit thread, and i wonder if there is any monitor using it.
I don't like glossy coating on monitors but i don't like that extra colour layer xD (does glossy coating add a colour layer too?).
In part i'm waiting for the rtings review of the Viewsonic XG270 to see how it has these :) .
EDIT: I usually get eye strain with any monitor i've tried, and i was thinking that maybe i had to use it with less brightness, and now i don't know if these coatings can be the cause(?).
xenphor
Post by xenphor » 14 Mar 2020, 19:14
Okay I just received the Viewsonic xg2402, and after using it for a little bit, it does not seem to have the weird sheen that the AOC 24G2 had which is good. The TN panel definitely looks a bit washed out and the gamma shifts from the top to the bottom, but I think I can get used to it.
Moving the mouse cursor on the desktop appears a bit different at 144hz on the Viewsonic compared to the AOC; it almost appears less smooth, but I think that might be due to the lower amount of motion blur. I can more easily pick out the after trails of the mouse cursor on the Viewsonic, whereas on the AOC they kind of blurred together.
edit: One thing I've noticed is this mesh pattern that appears when the framerate is low: https://pcmonitors.info/wp-content/uplo ... tterns.jpg. I first noticed it when playing Mega Man X in Dosbox because it runs at a very low frame rate and has large areas of uniform color.
sempronius
Post by sempronius » 15 Mar 2020, 08:47
nixon wrote:
10 Mar 2020, 05:28
sempronius wrote:
20 Feb 2020, 13:41
I currently experience eye strain using my LG 27GL850. I am surprised, most people do not report any such issues. I also had eye strain with the Dell S2719DGF and the AOC C24G1 and AOC 24G2U, whilst there is zero eye strain with a Viewsonic XG240R or an HP Omen X 25f. I cannot find out what the reason for these problems is.
How does the XG240R compare to the XG2402?
Sorry for the somewhat late reply.
Well, the XG2402 was just like the XG240R: no eye problems at all!
xenphor
Post by xenphor » 16 Mar 2020, 19:57
Unfortunately, even though it doesn't have the same annoying sheen that the AOC 24G2 had, I'm returning the Viewsonic XG2402 because the colors were just really bad. I tried adjusting all the settings and nothing could help the really washed out look. It was quite a bit more washed out than any other monitor I've had, so maybe something was wrong with it. I had my cheap Acer chromebook with a TN panel right next to it and it looked so much better.
It's too bad that there aren't any cheap 75hz IPS Freesync displays (that are recommended at least), because I don't even really care that much about high frame rate, although it is nice. Freesync just works and it's nice not worrying about having enough GPU power to spare for tearingless vsync off with RTSS.
Post by Chief Blur Buster » 17 Mar 2020, 16:06
xenphor wrote:
14 Mar 2020, 19:14
That's part of it.
However, make sure your mouse is already set to 1000 Hz.
xenphor wrote:
14 Mar 2020, 19:14
That's an artifact of LCD inversion logic that is easiest to see at low refresh rates on TN panels. Normal LCD inversion is invisible but sometimes it produces chess-board texturing in solid colors. It is seen on many 144Hz TN panels, though many 240Hz TN panels have it more invisible.
xenphor wrote:
16 Mar 2020, 19:57
460Hz FreeSync can also work if the monitor is slightly overclocked (e.g. 61Hz or 62Hz) so you can cap 1Hz or 2Hz below Hz using RTSS or a millisecond-accurate framer rate capper.
75Hz does give you more headroom for slightly less accurate 60fps frame rate capping. But as long as the emulator has sub-milisecond-perfect framepacing, I've seen some users overclock 4K 60Hz FreeSync monitors to 61Hz or 62Hz, cap to 60fps, and use it with emulators without lag. 4K 59fps at 60Hz VRR, since sometimes there's cheap 4K 60Hz FreeSync IPS on sale. At low Hz (60Hz) you can tighten your VRR "3fps below" margin to as little as "0.5fps below" if your specific emulator has impeccably perfect framepacing whereupon no frametime (interval time between frames) is faster than shortest refreshtimes.
The reverse technique is live with 60Hz, and intentionally slow down the emulator to 59fps (59Hz) with all the attendant audio slowdown, etc. So that you maintain a small cap differential VRR fps-below-Hz to aviod the dreaded VSYNC ON input lag with VRR technologies.
This is a configuring/tweaking headache -- but potentially easier than RTSS Scanline Sync -- these are additional options to keep an eye out for too.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
xenphor
Post by xenphor » 17 Mar 2020, 16:41
Chief Blur Buster wrote:
17 Mar 2020, 16:06
I'm not really interested in a 4k 60hz Freesync monitor, but I would be interested in 60-70hz 1080p IPS Freesync display. The only reason I specified 75hz is that I thought it might be easier to source a decent IPS panel at that refresh rate, but I'm guessing since most people want 144hz+, it's not going to be any cheaper/better.
Scanline sync achieves what I want in native pc games for input lag/smoothness, the only problem is the GPU power needed and that it is not a hardware solution. At this point it looks like I would be better off upgrading my GPU, so I can have more horsepower to spare for scanline sync while the VRR market stabilizes.
Unfortunately I don't have a solution for emulation. If it's a 16bit system or below and supported in retroarch then it's doable, but anything else is a crapshoot.
x0fff8
Post by x0fff8 » 18 Mar 2020, 02:59
Posting in this topic to report, I feel eye strain when using the vg279qm with ELMB on. Is it normal for ELMB (black frame insertion) to cause eye strain over prolonged use? If this is the case, will all other monitors with a similar implementation cause eye strain?
Thanks!
