Hi,
I am trying to flash my SSC325 Processor from SigmaStar having SPI NOR flash of part type ZB25VQ128ASIG using ISP Tool in windows 7. While trying to flash I get error of Device Type not detected. If I manually select Device Type as ZBitnnn128 from Device Tab in ISP Tool then the error goes. Here what I expect is the device type should get selected automatically as per the tutorials available over the net.
Now If I select the IPL.bin file and click on "Run" then after sometime I get below error:
Start time: 5:52:58 PM
Program File Ready !!
Erase Message : Erasing ...
Erase Message : Erasing at 0x000000
[error] unable to disable write protect (BP bits)!
flash status 0xFFFF
Retry Message : Retry 1 Time(s).
User Break Processing !!!
Can anyone guide me how to flash all the images for SS325 processor using ISP tool. From SSC325 datasheet I have checked that this processor can boot from SD-Card as well. Can anyone share the steps of how to flash and boot from SD-Card.
Thanks.
SSC325: Device Type Not detected in ISP Flash Tool
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
