Best settings on Benq 2420z?
PUNCHRULLE
Post by PUNCHRULLE » 17 Apr 2014, 20:17
I have tried alot but cant really get the perfect colors/brightness etc.
Anyone found any good ones? im not using blur reductinon atm
Re: Best settings on Benq 2420z?
Post by Chief Blur Buster » 17 Apr 2014, 21:35
Currently, the easiest way to get much better colors is to install the .icc profile file for the XL2420Z. It makes colors much better.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
PUNCHRULLE
Post by PUNCHRULLE » 18 Apr 2014, 00:22
Yeah i installed the display pilot if that is what u are meaning,im using movie preset, decent colours
lol37
Post by lol37 » 18 Apr 2014, 17:55
if you can afford it buy a colorimeter like the x-rite i1pro display... if really you wanted so...
Post by Chief Blur Buster » 19 Apr 2014, 08:58
Yes, a colorimeter helps.
You can also install the .icc file that's available for the XL2420Z to give its colors a good jumpstart.
Knxwledge
Post by Knxwledge » 19 Apr 2014, 09:01
Chief Blur Buster wrote:Yes, a colorimeter helps.
Where can I find this .icc profile?
PUNCHRULLE
Post by PUNCHRULLE » 19 Apr 2014, 22:29
Its on the cd that came with the monitor
Knxwledge
Post by Knxwledge » 20 Apr 2014, 01:07
Ahh thats a bummer. I don't have a cd drive on my computer lol
lol37
Post by lol37 » 20 Apr 2014, 18:10
Calibrate your monitor here http://www.lagom.nl/lcd-test, at least the result would be as good as the icc profile included (better actually).
It's usually a gamma correction to be done, most of gaming preset are unrealisticly vivid or washed out.
Post by Chief Blur Buster » 20 Apr 2014, 19:37
Knxwledge wrote:Ahh thats a bummer. I don't have a cd drive on my computer lol
The .icc files can be downloaded in pcmonitor's review: http://pcmonitors.info/reviews/benq-xl2420z
