Page 1 of 2
Best settings on Benq 2420z?
Posted: 17 Apr 2014, 20:17
by PUNCHRULLE
I have tried alot but cant really get the perfect colors/brightness etc.
Anyone found any good ones? im not using blur reductinon atm
Re: Best settings on Benq 2420z?
Posted: 17 Apr 2014, 21:35
Currently, the easiest way to get much better colors is to install the .icc profile file for the XL2420Z. It makes colors much better.
Posted: 18 Apr 2014, 00:22
by PUNCHRULLE
Yeah i installed the display pilot if that is what u are meaning,im using movie preset, decent colours
Posted: 18 Apr 2014, 17:55
by lol37
if you can afford it buy a colorimeter like the x-rite i1pro display... if really you wanted so...
Posted: 19 Apr 2014, 08:58
Yes, a colorimeter helps.
You can also install the .icc file that's available for the XL2420Z to give its colors a good jumpstart.
Posted: 19 Apr 2014, 09:01
by Knxwledge
Chief Blur Buster wrote:Yes, a colorimeter helps.
Where can I find this .icc profile?
Posted: 19 Apr 2014, 22:29
by PUNCHRULLE
Knxwledge wrote:Chief Blur Buster wrote:Yes, a colorimeter helps.
Its on the cd that came with the monitor
Posted: 20 Apr 2014, 01:07
by Knxwledge
PUNCHRULLE wrote:Knxwledge wrote:Chief Blur Buster wrote:Yes, a colorimeter helps.
Ahh thats a bummer. I don't have a cd drive on my computer lol
Posted: 20 Apr 2014, 18:10
by lol37
Calibrate your monitor here
http://www.lagom.nl/lcd-test, at least the result would be as good as the icc profile included (better actually).
It's usually a gamma correction to be done, most of gaming preset are unrealisticly vivid or washed out.
Posted: 20 Apr 2014, 19:37
Knxwledge wrote:Ahh thats a bummer. I don't have a cd drive on my computer lol
The .icc files can be downloaded in pcmonitor's review:
http://pcmonitors.info/reviews/benq-xl2420z
