from what I can tell if I am comparing it to the now available 2746S, it seems to be "DyAc+" instead of just DyAc , (no idea what the difference will be), and freesync compatible when DyAc+ is turned off which is a good thing for having options at least, but what else? maybe it will have the newer generation 240hz 0.5ms TN panel ? seems so from looking at the 2746S spec sheet :
https://zowie.benq.com/en/product/monit ... 2746s.html
there is also a korean review of 2746S here : https://translate.google.com/translate? ... 2F57666851
but the translation seems to work a bit iffy unless you manually copy and paste the sentences or paragraphs you are interested in to a normal korean -> english google translate window, from that review at least things seem good on the 2746S, with this in mind the 2546S seems like a nice option? interested in getting this monitor and trying out the blur busters 182 hz custom VT tweak on it anyway !
does anyone know what will be new with benqs xl2546 "S" compared to the older non-S model ?
Re: does anyone know what will be new with benqs xl2546 "S" compared to the older non-S model ?
Yup you guessed it right.
New panel & I guess high VTs out of the box, the Korean persuit camera looks smooth af with very low crosstalk.
Where's the Korean pursuit camera pictures? I can't find them on this review.
There's a TestUFO test of DOTA2, but that's not a pursuit camera test.
https://www.youtube.com/watch?v=0XqY64lUlLUChief Blur Buster wrote: ↑10 Mar 2020, 12:53Where's the Korean pursuit camera pictures? I can't find them on this review.
this is the video in question, don't know if he tracked it correctly and i wish he showed the top and bottom, but it does look decent if that's 240hz.
