Which is better in terms of build quality and performance-wise? which has better IC chipset?
thanks.
XL2411P Vs ASUS MG248QE
Re: XL2411P Vs ASUS MG248QE
While I like many ASUS models, and am a huge fan of other (higher end) ASUS models, the MG248QE is a lesser mortal compared to that versatile BenQ workhorse.
- XL2411P is strobe backlight compatible with gaming consoles (single strobe 60 Hz).
- XL2411P has a better strobe backlight, tunable via Blur Busters Strobe Utility which we created for these monitors!
- XL2411P is also overclockable to approximately 200-215 Hz with the Overclock trick (Out-Of-Range Popup-Dismiss Hack).
Because of these advantages, I definitely prefer the XL411P for this particlar monitor match-up.
Amazon Links:
ASUS MG248Q - 24" 1920x1080 TN 144Hz FreeSync
BenQ ZOWIE XL2411P - 24" 1920x1080 TN 144Hz
Disclosure: Blur Busters participates in the Amazon Associate program, an affiliate system for sites to earn income from links to Amazon.
Amazon Links:
But How can I fix the scanlines/ horizontal faint lines problem that occured to me on the XL2411P?
a temporary fix is, to turn the monitor off and turn it back on, after opening a game or something, also is it possible to update the firmware of the monitor easily through the windows, or it requires hard firmware update ?
If we get flicker (strobe), this monitor is normal.phaze wrote: ↑13 Mar 2020, 20:05But How can I fix the scanlines/ horizontal faint lines problem that occured to me on the XL2411P?
CPU: [email protected]
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC new! <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 21" Sony E530
HDD: SATA 1TB
I honestly don't know what you mean with the flicker ( Strobe ), the problem that happens to me is when I open a game or soemthing, I see faint horizontal gray lines moving across the whole monitor, so I need to turn it off and turn it back on to let it go, or turn off Instant mode off and On again to let them go, also it occurs constantly when the instant mode is off ( the horizontal faint gray lines )
