Hey, i was searching for a bit for a 240hz/low input lag/low ms/no motion blur "competitive edge monitor" and was getting quite bad anxiety for picking the best one since, its hard to decide since i have an amd gpu so i cant use ulmb and a lot of monitors blur reduction relies on that. may i get some suggestions/list for some 240hz with the motion blur reduction on,low input lag and ms monitors.
Pref tn panels since cheaper and i don't need the colours/viewing angles
cant buy benq since all of them are out of stock on amazon and anywhere else the taxes become unreasonable
TY
Competitive monitor that isn't benq
Re: Competitive monitor that isn't benq
If you're not on 60fps that's a good excuse to wait for the updated XL2546 aka XL2546S.
Otherwise XF252Q & KD25F are your options, both have a strobing future IIRC the KD25F is more adjustable with lower crosstalk.
