So you think the Acer XV273X is a better deal than the Asus VG279QM?RLCScontender wrote: ↑19 May 2020, 13:46UPDATERLCScontender wrote: ↑17 May 2020, 17:46Acer Predator XB273 x review-----MAY 17th 2020. The only Native G-sync IPS 240hz monitor.
I'm keeping the acer predator xb273 x. The excellent low input lag was more noticeable than the slower pixel response time of 4.3ms because when i compared to to my MSi MAG251rx, i hardly noticed any difference in practice(although the MSI MAG251rx was slightly more clear due to a 3ms g2g average.
I graphed out the data @ 60hz native refresh rate input lag for the MSI MAG251rx and i got about 25ms input lag(2.4ms input lag at 240hz). Keep in mind, 25ms is above average becuase if you compare it to the Asus VG279qm/VG259qm the input lag @60gz that i graphed out is around 37-40ms. Difference is the g2g average is still 3ms @60hz, but because the refresh rate is lower, it's not as CLEAR compared to 240hz. Higher refresh gives better motion clarity regardless of g2g average.
yes, the Acer Predator/Acer Nitro(THEY ARE ALL THE SAME PANEL) although on the slow end on PEAK performance, the ridiculously low input lag make up for it(2ms for the predator, 1.6ms for the acer nitro xv273x).Both also have excellent input lag at 144hz and 60hz, at around 13ms. That may not sound "good" but if you compare it to the asus(40ms the worst i've measured) and the MSI(25ms), i was able to play Smash bros ultimate wayyyyy better on the acer predator 240hz ips.
tlld;lr
it all comes down to what you value the most. Peak performance vs low input lag. I'm keeping both the MSI(peak performance) ANd the predator(low input lag) and i will not return either monitor. I will have to flip a coin in the next 4-5 months when the 360hz alienware IPS monitor come out on which i should sell.
The original price is about the same.
