The asus VG 279QM seems to perform really well, but i'd prefer a 25inch monitor due to PPI and desk space etc.
Does anyone have review from Asus VG259QM?
Does the Asus VG 259QM perform similiar or better than the Asus VG 279QM? Does anyone know or tested it?
I'm also curious that the overdrive for the 25inch could be slightly different than the 27inch variant?
Asus VG279QM vs VG259QM
Re: Asus VG279QM vs VG259QM
Forii had both. He claimed that he saw overshoot if he put 80 OD at 240hz on the 25 inch version. Whereas on the 27 inch version, he saw no overshoot on 80 OD. Feel free to message him.
Me personally, i have nevee tried the 25 inch version so i cant say. Their hardware and tuning should be the exact same though. And any differences is either a defect or panel variance.
I believe they will be available in US soon, if you're hoping to test one. https://www.shopblt.com/item/asus-24.5- ... ailabilityRLCScontender wrote: ↑07 May 2020, 04:55Forii had both. He claimed that he saw overshoot if he put 80 OD at 240hz on the 25 inch version. Whereas on the 27 inch version, he saw no overshoot on 80 OD. Feel free to message him.
27 inch version had better overdrive, maybe because difference in ppi.
But 25 inch version has better colors, and I mean here white color, when on 27 inch even after calibration it was yellowish.
i am using the 25 inch variant. yea the colors are good. the whites are white. i am using it beside a dell IPS p2217h monitor. after calibration, the whites look whiter than the dell IPS
Aw. i really wanted a 25inch due to ppi and deskspace, but the worst overdrive seems to be putting me off from purchasing the vg259qm
by any chance did you think you receive a faulty 25inch display? therefore the worst overdrive?
I am using vg259qm with OD 80. Playing csgo in game, looks good to me. No pixel distortion in game at all. Just get it.
at 240hz or 280hz ?jnashville wrote: ↑09 May 2020, 08:42I am using vg259qm with OD 80. Playing csgo in game, looks good to me. No pixel distortion in game at all. Just get it.
Do you strobe on your VG259QM?jnashville wrote: ↑09 May 2020, 08:42I am using vg259qm with OD 80. Playing csgo in game, looks good to me. No pixel distortion in game at all. Just get it.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
i am using on 280hz refresh rate and ELMB sync off. gameplay wise is good for me. cant feel any input lag and display is very responsive.axaro1 wrote: ↑09 May 2020, 09:29Do you strobe on your VG259QM?jnashville wrote: ↑09 May 2020, 08:42I am using vg259qm with OD 80. Playing csgo in game, looks good to me. No pixel distortion in game at all. Just get it.
