Has anyone found a way to update your firmware on the XL2540?
ayeTop
Post by ayeTop » 23 May 2020, 01:57
I want to switch to a higher version from 2. Anyone have found out how without having to buy something?
AddictFPS
Re: Has anyone found a way to update your firmware on the XL2540?
Post by AddictFPS » 23 May 2020, 03:50
Viewsonic XG270 can be updated with its software and USB cabel. BenQ Zowie do not supply this solution ? you've talk with BenQ support ? Firmware update can brick the monitor, take care with unnofficial solutions if you can't go back if something goes wrong !
