XL2540 audio
sunhunter
XL2540 audio
Post by sunhunter » 23 May 2020, 15:06
Hello, i have xl2540 and it has audio and mic jack on left side, is it better to use it instead of motherboard? My motherboard is really cheap/budget one so i assume it has really bad audio.
I won't have any delay or something?
DukeDice929
Re: XL2540 audio
Post by DukeDice929 » 23 May 2020, 16:42
You mean audio from your graphics card via HDMI or DP? It is not always better than modern motherboards internal codec (even cheap). For better sound use discrete card (i.e. ASUS XONAR, Creative Sound Blaster etc).
My bad English :0
sunhunter
Re: XL2540 audio
Post by sunhunter » 23 May 2020, 17:09
DukeDice929 wrote:
23 May 2020, 16:42
https://prnt.sc/smk26d so if i connect from this audio i get is from my gpu? I thought monitor had his own "thing" to give sound. ty for clearing up.
MrStinkybutt
Re: XL2540 audio
Post by MrStinkybutt » 24 May 2020, 15:15
Use the audio jacks at the motherboard
