0.5ms vs 1ms 240hz TN: Any visible difference?
azami8m
Post by azami8m » 24 May 2020, 09:56
HI, can someone who tried both the newer generation of 0.5ms 240hz TN panels (xf252q, kd25f, xl2546s..) and the old one give feedback about how different they look IRL? (my main concern is that 1ms is enough for 144hz but maybe a limiting factor for 240, hence the benefit from a faster panel)
Personally i'm stuck with a 75hz and want to upgrade to a zowie XL2546, i can't get the newer xl2546s for at least a month after the release where i live so i'd rather grab the older panel if there is no much difference.
Thanks for any inputs!
kofman13
Re: 0.5ms vs 1ms 240hz TN: Any visible difference?
Post by kofman13 » 24 May 2020, 12:25
also curious about this
Q83Ia7ta
Post by Q83Ia7ta » 24 May 2020, 15:12
Same or almost same for me. BenQ XL2540 and Acer XF252Q.
sk1p
Post by sk1p » 24 May 2020, 15:26
I had BenQ XL2540 then Alienware AW2518HF, then LG 27GK750F, and the last was Acer XF252QX. Now I have Asus VG279QM. Response time of all 240 TN looks the same for me, but in term of input latency my opinion that VG279QM>Acer XF252Q>AW2518HF>27GK750F>XL2540. Guess xl2546s will be the same as XF252QX, but it's not exactly.
Post by Chief Blur Buster » 24 May 2020, 18:16
Ideally, 0.5ms vs 1.0ms difference is 1 pixel for every 2000 pixels/sec.
But in real world, real GtG(100%) may vary a lot from this — however, 0.5ms GtG panels will usually have a better looking “GtG heatmap” than 1ms or 2ms GtG panels (colors are less likely to ghost during reduced overdrive settings). For example, a ghosting/corona-free 4ms GtG (without overdrive) is sometimes much easier to achieve on a 0.5ms GtG panel than a 1.0ms GtG panel.
Some people have observed that 0.5ms helps the following:
— Noticeably better behavior at mid frame rates (e.g. 144fps at 240Hz)
— Less ghosting/corona at reduced overdrive settings (native GtG is faster even if not 0.5ms vs 1.0ms)
— Less strobe crosstalk at higher refresh rates
There more information found in Pixel Response FAQ: GtG versus MPRT
That said, the best 1ms GtG panels can be better than the worst 0.5ms GtG panels. There are over 60,000 different GtG numbers for a single screen, and the single GtG number is simply an average only.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
PirateNinjaInPijamas
Post by PirateNinjaInPijamas » 25 May 2020, 00:13
I saw a lot of difference from my previous AW2518H to my current Omenx25f in terms of responsiveness and input lag. So yes the difference is there if you search for it. If you don't, get the one with the best price / deal. From 75 hz to 240 hz you will be a happy man anyways.
Dirty Scrubz
Post by Dirty Scrubz » 25 May 2020, 02:08
I think you'll notice input lag differences more than anything else.
azami8m
Post by azami8m » 25 May 2020, 19:32
Thank you all for the inputs, since it will not be locally available for 2+ months i just went with the 4XL2546.
