Eliminate overshoot HP Omen X25f
- BTRY B 529th FA BN
Is there a way to eliminate overshoot on the fastest preset on this monitor?
Re: Eliminate overshoot HP Omen X25f
Overshoot is a result of the high overdrive level.https://blurbusters.com/faq/lcd-overdrive-artifacts/. So I think the only way to lower this overshoot is by lowering the overdrive however I could be wrong, I am not very knowledgeable in this but this is what I assume.
"The response time can be customized, and there are four different levels. We recommend level 3, as it delivers the best response time with the least amount of overshoot. Level 4 has significantly higher overshoot, and there is almost no improvement to the response time, so we don't recommend it."
https://www.rtings.com/monitor/reviews/hp/omen-x-25f~
No.
No.
